Evo9 died while making a pull wont start!
#31
Finally got around to pulling the timing cover off and just as I thought it was the crankshaft position sensor. Fo some reason the main bolt that bolts into the crank and holds all the pulleys in place started to back of a little bit. This caused all the pulleys to shift a slight bit and the reluctor ring started rubbing against the crank sensor. Also the car threw a P0335 "Crankshaft position sensor circuit A" code. I priced it out online and its around 50$ which isnt too bad. I also have a 2g DSM sensor laying around. Does anyone know by chance if its the same?
#35
Apparently they are the same...well the sensor and plug are anyway, the harness on the DSM one is about 6 inches shorter ...I cut the old sensor off and soldered the dsm one on. The car fired right up.
teudmunki9mr
32
Mar 29, 2010 12:16 AM
TrinaBabe
24
Dec 7, 2005 09:59 PM
