Sticky Accelerator
Sticky Accelerator
Hey folks,No, I don't have four door toyota with Mitsubishi stickers and a huge wing... : ) lol But I do have 2005 GSR with 55K on the odo. The past 3-4 days my accelerator gets semi-stuck or rather not compliant when I press the accelerator 1/4 (and sometimes 1/2) way down. Is this a lubrication issue, spring going bad or do I need to eat a cheese burger? Has there been a Recall for this?Somebody enlighten me?
Happened to me last year.Pull the intake hose off the throttlebody and you will find build-up around the throttle plate.Brake clean a rag and hold wide open the throttle and wipe the build-up away.Not a good idea to spray directly into the body!
for all you guys saying spray thottle cleaner or anything into throttle body make sure you cover the little hole in front of throttle plate and behind it. It leads to the iac and if cleaner gets on it, it can fry. You can also get rpm hang from the iac having crud built up on the end of its piston. Pull it out and clean it with alcohol or something of that nature and then replace. Becareful when removeing and replacing iac cuz there is a oring seal on it.
