No Fuel Pressure...
No Fuel Pressure...
I recently intalled a custom double pumper system that worked perfect until i blew one of the line from the fuel pump inside the tank. (forgot to remove my test fit lines) Setup is Buschur replica with AN fittings/lines.
So after i removed the twins, -6an feed line and installed the full stock setup to make it home, the car wouldnt start.
Have Spark, just no fuel pressure.
No blown fuses (will check all again today)
Battery Is Strong
Everything turns on, and fuel pump primes but no fuel pressure to the rail. (new wb255)
No leaks, cracks, no blown Vac Lines.
Swaped in my old fuel pump (wd 255) and does the same thing. No fuel pressure to the rail.
I have not opened the fuel rail to see if any fuel is making it there, but my pressure gauge reads 0. Usually spikes to 40-43psi then slowly comes down.(AMS fpr Kit)
Is there anything i am missing, have not driven in a week.
Thanks for looking.
Battery Is Strong
Thanks for looking.
MisUnderStood
31
Nov 30, 2016 03:18 AM
Black_EVO_MR
Oct 30, 2016 07:18 AM
05EV08
May 13, 2016 10:35 PM
YFZracer32
Oct 19, 2015 12:03 PM
