Why can't i go pass 6.5k rpm?
Old Apr 10, 2010, 11:52 PM
CMoney's Avatar
Hey everyone,
I'm still a newbie with my evo but i just wanted to know why can't i go pass 6.5k rpm. Every time i accelerate to try to reach 7k rpm it won't let me go pass 6.5k. It seems like it's already reach red line because it just shuts off and wants me to shift. Any help will be appreciated.
Old Apr 10, 2010, 11:56 PM
evogirl916's Avatar
lower rev limit set by tuner/previous owner? if not it could be bad gas causing timing pull/ignition cut
Old Apr 11, 2010, 12:04 AM
rabit1132's Avatar
i know evos are not the same as an s14 but i had a similar problem with my s14 and it was a simple fuse. forgot which one it was though. and dont know how it effected my rev limit either. but it worked.
Old Apr 11, 2010, 12:38 AM
CMoney's Avatar
Hmm.. I don't know. I mean Everytime I hit boost it would just reach 6.5k and the rev meter starts bouncing. The car drives fine but I'm just a little worried why it won't not pass 6.5 rpm.
Old Apr 11, 2010, 01:50 AM
CJ2X's Avatar
What mods do you have on the car?
Old Apr 11, 2010, 06:56 AM
ranz's Avatar
probably in valet mode(if you're using tephra's mode)?
Old Apr 11, 2010, 10:12 AM
Boost_Inspired's Avatar
does the car have a stock air box? if so check to see if any of the foam got sucked into the box and is blocking the maf screen. Happened to a friend of mine on his 8.
Old Apr 11, 2010, 10:23 AM
alloutDSM's Avatar
^ never heard of that but always check, most likely the 2 step limiter....
Old Apr 11, 2010, 11:13 AM
heel2toe's Avatar
^The two step is only enabled when the car isnt moving which is not the case here. This sounds like the actual rev limiter has been lowered. If I were you I would have a competent tuner check out your car. A proper tune will make your car run so much better not to mention the fact that they could raise that rev limiter.
Old Apr 11, 2010, 12:10 PM
CMoney's Avatar
The car is stock at the moment besides k&n drop in filter and act 6 puck.
For some reason I think the rev limit did lowered. I'm going to make a appointment with a tuner and see whatsup with the car. Thanks all.
Old Apr 11, 2010, 12:14 PM
alloutDSM's Avatar
eh its in the same location in the ecu, tech the 2 step is just a stationary limiter as opposed to the moving limiter, just have a tuner change your parameters.
Old Apr 11, 2010, 12:35 PM
heel2toe's Avatar
^I am not sure what you mean by same section. They are two different parameters. Here is a screen shot from Ecuflash. As you can see one is called stationary rev limiter aka two-step and the other is rev limiter, most likely set around 6500 in his case.
Old Apr 11, 2010, 12:40 PM
alloutDSM's Avatar
dam its been a while since i looked at ecuflash i could have sworn they were in the same section but forgot they both fell under MISC, mybad...anyways to the OP ^ the image above is what we were talking about sorry for the confusion.
Old Apr 11, 2010, 01:33 PM
CMoney's Avatar
No problem, I am learning a lot as we speak.
Old Apr 15, 2010, 04:00 PM
mnm27mnm's Avatar
It might be that timing is not correct, i heard of some other cars having that problem because of their timing
Quick Reply: Why can't i go pass 6.5k rpm?
