Dying and PCV
Old Apr 12, 2010 | 03:26 PM
Rp.cudd's Avatar
Dying and PCV
Do your cars almost die everytime you get into boost then go into neutral? I will get into boost around 5kish, and if i get off the gas and go to neutral the rpm drops to around 200 if not dies completely. It like catches itself at a very low rpm then kicks up again. Also, i cannot get my PCV valve to stop popping off i replaced it, no change, any ideas?
Old Apr 12, 2010 | 03:33 PM
K1tt3n5's Avatar
a small amount of jb weld.
Old Apr 12, 2010 | 05:19 PM
evokid511's Avatar
my car does the idle drop thing but my pcv is fine
Old Apr 12, 2010 | 05:33 PM
EvoVan's Avatar
^^Same here.
EvoVan's Avatar
*idle
Old Apr 12, 2010 | 06:20 PM
evokid511's Avatar
Originally Posted by EvoVan
*idle
edited thank you!
Old Apr 12, 2010 | 07:09 PM
EVO8emUp's Avatar
Stock BOV?
Old Apr 12, 2010 | 09:17 PM
Rp.cudd's Avatar
Hks ssqv
Old Apr 12, 2010 | 09:28 PM
DragonDog's Avatar
Originally Posted by Rp.cudd
Hks ssqv
Ditch it and get a recirc valve.
Old Apr 13, 2010 | 09:21 AM
Boosted Tuning's Avatar
Hks ssqv
This is your problem.
It not wise to use a VTA (vent to atomosphere) BOV on a MAF equipped car. (disregard this is you have your HKS BOV setup to recirculate)
Old Apr 13, 2010 | 10:26 AM
Eric Keely's Avatar
Mine does the same dying thing... I have injen intake and IX BOV.
Old Apr 13, 2010 | 10:47 AM
05blue8's Avatar
A tune can solve "some" of that...could be boost leaks also. Mine has been tested and tuned and it still happens, I just learn to put it in gear and pop the clutch to start it back up if/when it dies, roughly 1-2 times a day, i expect no less from the Evo tho
