SRS light and sinking brake?
first and foremost the brakes shouldnt have a connection to the SRS light being on. pull the codes then further address the SRS concern. as for the brakes also make sure you do not have any leaks elsewhere in the system.
well..this morning after i took pads and rotors out and reinstalled it..problem went away...weird... but srs light still on but probably due to that i disconnected the crash sensor without disconnecting battery first...im getting the code cleared..problem should be all solved...thanks for all the help
