abs indicator light came up...
Old Apr 14, 2010 | 07:47 AM
feimax's Avatar
Hey guys I realised tat my abs light came up when I came down from the carpark... then I stopped and turned off the ignition and crank the car again it disappeared... I'm just worried there might be some problem wat do u guys think?
Old Apr 14, 2010 | 10:46 AM
mrg7243's Avatar
i know on some fords that if you throw the rear end out(drifting) or hit some bumps hard it will throw the ABS sensor outta wack, and like you said restarting the car clears it, since the ECU goes through a set of scans before the engine is cranked over. And it read the ABS sensors is fine.
Old Apr 14, 2010 | 06:52 PM
Berts24's Avatar
did it come back on?? On my accord you would turn it on and nothing, drive it for a few feet and it would come on, turns out I had TWO bad sensors, and they weren't cheap!!
Old Apr 14, 2010 | 07:17 PM
cybertrax's Avatar
It happened to me a few times when I hit some bumps, but it went away that very second.
Old Apr 14, 2010 | 07:32 PM
darkside4G63's Avatar
check your brake fluid.
Old Apr 15, 2010 | 01:18 AM
feimax's Avatar
currently its gone hahaha i'll hope it stays tat way... but i think i'll bring it to the workshop nxt week to let them double check
SilverEmperor
Aug 27, 2015 01:34 PM
EvoVIIIFL
Jul 21, 2015 08:11 PM
dtenev2
Jan 14, 2015 07:17 PM
CanadianEvo
Jun 16, 2012 11:24 AM
Midnightevo8
24
Feb 18, 2010 06:58 PM
Quick Reply: abs indicator light came up...
