Locked my key in, need help - Yes I know I'm stupid.
pop the lock
Been there done that, I actually thought I could leave the key in and the car on and just take my key fob and still get back in......ha go me that made for a long day. Use at your own risk, the EVO's locking mecinism is on the back doors thats the only way Ive seen to get in, you lodge a peice of wood cut like a V into about the middle of the window on the rear passenger door and then get a small rod or coat hanger notched or hooked and run it from the middle over to the door handle, pull up and wallah. But definatly at your own risk its always better to use a lock smith.
lock
It didnt work for me, I have and 05 EVO, The car was still on key in the ignition and all the doors were locked. I had the key fob in hand and nothing unlocked. I called the lock smith after he came out and opened it up I sat and talked with him for little while even tried to get him to sell me his set up to unlock the door. Took all but 30 sec to unlock it.
Was it running or just in the "ON" position?
I decided not to try to play mcgyver, locksmith on the way. I have roadside assistance through state farm so no big deal anyway I guess.
lock
My girl was running, long stupid drawn out story. I had a bad cell in the battery and had to hit walmart for something so thought Id be slick and the the car running and just go in and get what I needed then come out hit the auto store and get a new battery. what was supposed to be a 15 min venture out turned into a 2 hour trip.
All the time you took to post this thread, you could have called a locksmith and had the door open in a few minutes. Or you could go to the dealer and get a new key made. There's far better options than breaking the window.
edit: Nice to see you got it taken care of!
It's so easy to break into these cars it's not even funny. You can reach the lock with a wire hanger or a thin piece of sheet metal through the wether stipping along the B piler/between front and rear doors (the 30 second way).
And when that fails there is always a Home Depot "slim jim"; sheet metal and tin snips (ten second way).
http://www.clksupplies.com/shop/imag...Slim%20Jim.JPG
This happened to me before. Your key fob doesn't work with the key in the ignition, regardless of position.. I just called a tow company and they used a tool to open the door. Took about 2min. Just stuck it down between the glass and weather stripping. No marks or anything.
Having a dealer cut you a key will be pricy but it will kill two birds with one stone. Think about it, either way, it's a good idea to get a spare key. By all means, I'm down with trying to be creative but I wouldn't want anything bad to happen to you, or...your wallet.lol accidents can get costly. Believe me I know. Just my 2cents, take and keep, or to throw in the wishing well.lol
Call a locksmith - tell them you're locked out with key in car and need the door lock picked. Ten minute job - simple locks in the door. Probably cost you $50 plus a service call. Certainly less that a window and no paint or other damage.
