Help Backfire
Old Apr 24, 2010, 04:50 AM
  #31
widge's Avatar
ok i kinda narrowed it down to either AFM or Fuel Reg. Just need to find a AFM to test
Old Apr 24, 2010, 04:51 AM
  #32
cfdfireman1's Avatar
no CEL?
Old Apr 24, 2010, 05:04 AM
  #33
kronic420haze's Avatar
my line popped off for my fuel pressure regulator once and did something similar but my idle would jump up and down a few hundred rpm
Old Apr 24, 2010, 05:16 AM
  #34
Evoryder's Avatar
Check your car for codes. Try inspecting the maf, almost seems as if airflow is blocked. Start the car without the maf plugged into the harness.
So when you did your boost leak test how long did you hold boost till it went to zero psi.
Old Apr 24, 2010, 05:30 AM
  #35
widge's Avatar
I havent completed a Boost Leak test as of yet as i dont really know how.
If i unplug the AFM it seems to make no difference if any it allows the car to start a little easier.
Is there some kind of test i can do on the AFM?
No codes on the car, **** the car doesnt even code when i unplug the AFM
Also all the lines are attached to the reg
Old Apr 24, 2010, 07:41 AM
  #36
Evoryder's Avatar
3 pages and you haven't done a boost leak test. Search "Ted B boost leak test"
Old Apr 24, 2010, 07:43 AM
  #37
blkmkIII's Avatar
not a bakefire there guy.. unless your car is carbed.. it didnt backfire.
Old Apr 24, 2010, 03:28 PM
  #38
https://www.evolutionm.net/forums/ev...g-how-why.html
Old Apr 24, 2010, 04:56 PM
  #39
widge's Avatar
Whats the popping through the exhaust then?
Old Apr 24, 2010, 07:26 PM
  #40
widge's Avatar
Tried new AFM and still wont start, the car doesnt start anymore could this still indicate an air leak?
Im going to bunnings to get the stuff to do an air leak test
Old Apr 24, 2010, 08:40 PM
  #41
Evoryder's Avatar
Maybe you damaged your mOTOr...i would tow it to a shop so they can pull the head. For further inspection.
Old Apr 24, 2010, 08:43 PM
  #42
GG_9_SE's Avatar
have u checked under th oil cap? Any milky substance in there? how about check to c if there is any anitfreeze in it.. Any oil in it at all? check everything over.
Old Apr 24, 2010, 09:02 PM
  #43
widge's Avatar
i went to bunnings to make a air leak tester and they had nothing i could use.
I moved the AFM to the throttle body eliminating any leaks in the cooler pipes still wont go.
I had the rocker cover off, to check valves springs there all good, no milky residue or any oil where it shouldnt be.
I did a comp test 175psi across all 4
i checked coils they seem to be sparking out of the car i checked its getting fuel.
Checked the bottom Crank Pully had it on the T and the cam gears line up properly
The only other thing i can think of is Cam Angle Sensor or Crank Angle sensor
Old Apr 24, 2010, 10:01 PM
  #44
widge's Avatar
Also the car is now throwing engine code, after about 10 start attempts, but when i check it with evoscan it says there are no stored DTC's WTF?
Old Apr 24, 2010, 10:47 PM
  #45
widge's Avatar
I went to bunnings, they had nothing there.
The car wont start at all now, i have a few people leaning towards a dead Cam Angle Sensor, i have a mate with an Evo 5 are they the same sensor?
Quick Reply: Help Backfire
