Evo MR 6-spd tranny oil change, diagram needed pls
hey guys i did a bit of searching and could not find a 6-spd specific diagram. I want to make sure which is the fill hole. Can someone supply a 6-spd specific diagram please.
thanks
thanks
The fill hole and the drain hole are both on the driver's side of the transmission. you'll have to remove some of that plastic crap to get at it probably. They are both plugs with hex wrench openings in them. the lower one is the drain, the top one is the fill. You'll have to open the bottom one to drain it, then replace that bolt, then open the top one with the hex wrench opening to fill it. thefill hole is the highest one. the car must be completely level while filling. you fill until you get to the bottom of the fill hole opening...basically you fill until the **** starts coming out. then replace the fill bolt. done.
the transfer case drain bolt is a 24mm bolt on the bottom of the TC. You drain/fill the TC just like the tranny. car has to be completely level, and you fill until it starts coming out of the opening. the fill hole for the TC is on the passenger's side of the TC toward the top of it. IIRC, the fill hole should be labeled "Fill" on the TC.
WTB[Mid-Atlantic]: WTB working 6spd trans or 5spd case
bitterchild
Jun 15, 2015 06:02 PM
06, change, diagram, disassembly, drain, evo, ix, lancer, mitsubishi, mr, plug, schematics, spd, speed, trans, transmission
