ProSport Gauges - Need Opinions on Color
I got 3 Prosport Amber/White Premium 60mm Gauges. I love them all. I got Boost and Oil Pressure initially. The AFR gauge that Prosport sells does not log so it's your call really.
I just wanted a third gauge to match in my cluster so I took the cheap way out and got Oil Temperature. You could get EGT, which seems to be a more common gauge that people get. But I would only worry about that if you're OCD like me and want the three gauges to match.
Otherwise, I'd recommend saving and getting a wideband O2 if you plan on tuning
Also, which millimeter gauges fit where the radio sits? Is that 60mm or 52mm??
I want to make sure I order the correct size...lol
I assume his Gauges are 60mm since they def. look bigger than the stock MR Gauges? I might need to measure to make sure.
Nope, when I bought the car, it came with the tri-pod Glowshift gauges...I don't like them so I'm getting ProSport. My brother has 3 ProSport Gauges set up where the stock radio should be but his radio moved to the bottom of that pillar.
I assume his Gauges are 52mm? I might need to measure to make sure.
Would you know where I can get the 3 gauge cluster piece on the arm of the car between the steering wheel and the driver-side door?
The color of my 3 gauge cluster piece is grey and I def. want it to be black...Maybe it would be easier if I just spray painted it black? IDK...lol. What do ya think?
Yeah the glowshift gauges look way too cheap to be on my car. I hate them.
If the ProSport Gauges are too big, then I will need to do like you did and move my radio down and get a straight pod and place the gauges where my radio currently sits.
I'll get the measurements of the Gauges today and let you know Bob
How much boost you plan on getting to? lol I figured 30 lbs. would be a great deal Also, DD?
As long as it's black and it fits whichever size my brother's ProSport Gauges are then sure.
Only reason I ask, isn't our cars more susceptible to being broken into when the gauges are in plain sight like that versus being semi-hidden (lets say at night) where the radio sits?
I guess I'm not trying to attract a lot of attention with them...Sorry for tossing back and forth on decisions here but I'm just curious...Cops probably will notice it too and that's never a good thing....
I'm just trying to exercise all options here
How much is the center gauge piece and where can you order it from?
