meth
Agreed. However with the stock turbo you won't make over 420ish on the stock motor. It becomes very hard to do.
OP if you do decide to run meth run at a min of 1000cc but I would run 1500cc. The stock turbos heat the air charge more than most people think and the extra 500cc of meth will help out
Goo luck and let us know once you get it on the dyno.
Mikey
Mikey
On the IX I would look into the S2s, if you had an VIII then I would lean more towards the Kelfords... The S2s always seem to have a better powerband, are more aggresive, and cheaper
Mikey
