need help on what you people think
i need help, i need your opinions on what you think is wrong with my car
now what im trying to show how far my wheel sticks out
Attachment 151575
this is my left side
Attachment 151576
this is my right side
i got into a curb accident on the left driver side. i had to replace the lower control arm, strut, spindal, link, rim, front sway bar. all the parts were used nothing new
i had a new axel put in as well but since the install the wheel is in more the wheel well then my right side. i never hit the right side before and this is my 2nd accident with the left side
i hope you can help thanks!
Attachment 151575
Attachment 151576
question:
when you had all the other stuff installed again, I'm assuming it was realigned? If so, was it with the stock settings? Stock settings have a toe in setting that may be even more exaggerated by a few of your curb rubs there.
Your wheelslook VERY similar, in fact I wouldn't have even spotted it if you didn't point it out. The only thing I can think of is that your right front tire slightly more toe in than the drivers side.
Please do not take my word as gospel, but if I could afford to, I'd probably verify your alignment settings. There are a number of conversations on the forums that cover this but let me save you some time:
zero out your toe in the front and rear.
-2 degrees camber up front
-1.5 camber in the rear.
If there is a setting that may alleviate the appearance of your right front tire "sticking out" more than the other, I personally believe its due to the toe in setting on that wheel. You may be able verify this by looking at the wheels/tires from the front of the car. if it looks like that they are both flush, that may confirm what I'm saying.
