bov for 30lbs of boost
Ill take the stocker once you get a new one
Get the forge RS it should hold 30lbs with no problem and is a direct replacement. the new tial is good but I think you need a flange for it.
Ive adjusted mine properly and no, I do not get any flutter issues whatsoever. A lot of people complain about flutter with the Forge RS, but flutter is related to either improper adjustment or a boost leak somewhere.
I did, at one point, have a boost leak that I could not find and I would get flutter and it was driving me nuts. I found the leak, addressed it, and voila, no more flutter.
You have a few choices, the APS twin vent is a good one, forge, synapse is very popular or you could send your stocker into dejonpowerhouse.com and have them modify it. I read an article that said they pressure tested it to 50psi and it leaked just a little. I am looking for the site so I can post the testing up here. http://evo.dejonpowerhouse.com/ this is the link and go to the leak stop kit.
Here is a how tohttps://www.evolutionm.net/forums/evo-how-tos-installations/260029-how-gus-mod-dejon-tools-leak-stop-kit-mr-bov.html
Here is the results from the 50psi test http://all.dejonpowerhouse.com/edit/BOV1.htm
