Heater core removal
Heater core removal
Hey I have been searching for a while and haven't been able to find out how to remove it (heater core). I have had a water leak for a while now when it rains and I have searched everyplace I could and the heater core is my last option. I was wondering if anyone could guide me in the right direction or tell me how to remove it.
Thanx for any information you have
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
If the heater core is bad it will leak antifreeze not water. You should be able to tell the difference by the odor.
If all you are getting is water then maybe the drain is plugged. I was under my car the other day and noticed the drain is right out in the open and easy to get to. So before doing anything else, I'd suggest you run a wire up the drain hose making sure it isn't plugged.
In answer to your first question, the heater box comes out after the dash is removed. Set aside a few days for that.
![EEK!](https://www.evolutionm.net/forums/images/smilies/eek.gif)
In answer to your first question, the heater box comes out after the dash is removed. Set aside a few days for that.![EEK!](https://www.evolutionm.net/forums/images/smilies/eek.gif)
and thanx for the info
I've done this myself recently for HVAC repair.
You need to pull the lower radiator hose. Watch out, it'll flow fast. And collect/dispose of the antifreeze. Then you'll have to get in the engine bay and get pliers and pull the two clips on the heater core hoses that run into the firewall.
If you need some help read my signature post. It'll explain some steps. You're going to have to drop the dash to get to it...
As I remember.....
A black rubber hose, coming through the firewall, at the bottom, a little towards the driver's side from center. It comes through horizontally and then points down, open at the end.
My former TA was wetting the front carpet. So, without jacking the car I crawled under. By the time I could reach the drain, I was stuck. I probed the drain and there was water up there, lots of it, and I could barely move. I got soaked.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
As I remember.....
My former TA was wetting the front carpet. So, without jacking the car I crawled under. By the time I could reach the drain, I was stuck. I probed the drain and there was water up there, lots of it, and I could barely move. I got soaked.![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
I assume the drain being mentioned is for the evaporator for the AC. If it's not raining and you run the AC on a hot/humid day do you get water? If not this drain is ok.
like others I have had this drain plug up (on my 1G). It's amazing how much water the AC removes from humid air.
Kidloco51
May 31, 2013 09:49 AM
Astro_Train
10
May 30, 2013 02:33 PM
