Greddy Evo II
Greddy Evo II
Did a search and couldn't find anything...
I read in a post from 2007 that the Evo II exhaust had to be modified by an exhaust shop to fit our Evo's. Is this still the case or did they modify the exhaust design to be a direct fit.
Also does anyone have any sound clips of this exhaust installed? I can't seem to find any
Thanks.
Thanks.
Easy install, fits perfect. Sounds good. Sound varies on whether you have a cat or not. Completely different depending on your setup. With a cat, it sounds stock. without, its a bit more aggressive, but still nothing too crazy. At work, so cant make you a sound clip. Sorry.
Have it, and agree with everyone above. I did nothing to the slight size reduction by the cat area. The only thing that I'd try to change (and will later) is the stock style bends before the muffler. Going to try and make it a little straighter. It is quiet until 4000rpm then gets louder. Freeway 65mph no problem with hearing the radio and having conversation at normal voice levels.
