Oil leak need help---------
Well my car has been leaking oil, and from what I could see when i got under the car, was the oil pan gasket. Im wondering if it could of been caused by crank case pressure. I think this because I have to zip tie my dipstick in or it shoots out. any imput would be helpful, thanks
Take the entire pan off and use a small amount. Use a new gasket also. If you have blow by that's bad enough to cause an oil pan leak, you may need to get it fixed. Try running it with a catch can on the oil dipstick and see if it stops leaking.
Well I knew from the beginning id need a catch can to releive the pressure, problem is i have $11.00 haha so ill try the cheapest fixes first. torque the bolts, then eventually throw a new gasket on, where can i pick one up and what am i looking to spend- thanks
Yeah, you will have to pull the pan and re-dope it. Nothing else will work.
Before you start, look things over closely. Chasing a leak, I once pulled the pan off an engine only to then discover the leak was from the valve cover. So, I had done considerable work for nothing.
