Upper Intercooler hose replacement
Old May 24, 2010, 10:04 AM
thedru13's Avatar
Is there an after market replacement for the stock upper hose? The one that connects to the Throttle body and the upper intercooler pipe? Upper is still stock so would need something to fit on the stock throttle body and upper pipe. Thanks.
Old May 24, 2010, 02:25 PM
turbolarry's Avatar
There's a number of them. The question to you is do you want to keep your stock battery or buy a small racing one?
Old May 24, 2010, 02:31 PM
rush63's Avatar
The OP wants to replace the hose only. Does he need to change the battery as well?
Old May 24, 2010, 02:45 PM
19DB794's Avatar
It sounds like he wants to replace just the UICP nylon coupling that goes from the intercooler piping to the throttle body. I'm not sure if the sell an aftermarket replacement for that piece but I'm sure you'd be able to find something to do that from this website: http://www.siliconeintakes.com/index...937307584b757a
Old May 24, 2010, 03:50 PM
thedru13's Avatar
this is correct thanks will see if I can find something. I think my oem hose is stretched. It will not stay on the throttle body. Used tclamps, hairspray so was thinking of just upgrading the hose. Still on stock IC and BOV so not sure it makes sense to replace uicp. I did replace the lower.
Old May 24, 2010, 03:53 PM
19DB794's Avatar
The UICP is more for looks. I don't think you'll gain much power if you replace it. Even if you go with the short route which I have. I replaced my UCIP since I ended up getting a small battery and I bought my IC piping as a package deal from ETS.
I know they sell kits to replace the factory couplings but at a cost of $230+ I don't think it's really worth it.
Old May 24, 2010, 05:50 PM
thedru13's Avatar
Yah was going to keep stock. I just can't seem to find something that will work. The stock one has some odd bends..
Old May 24, 2010, 06:22 PM
tpdc2's Avatar
I'm having the same problem too! My stock uicp keeps blowing off no matter what I do. I bought a t-clamp that didn't work, I tried using hairspray too. No matter what I do it blows off.
Old May 24, 2010, 07:05 PM
turbolarry's Avatar
Make sure the hose is seated properly past the bead on the throttle body and tighten the clamp with a ratchet/socket.
You can find a stock hose on ebay or maybe on here in the for sale section.
The closest aftermarket option that is close to stock is the Samco hose in black (but it's a set and not seperate);
http://www.extremepsi.com/store/cust...at=1493&page=1
Old May 25, 2010, 11:06 AM
thedru13's Avatar
Thats the hose but of course you can't just order one.. Have to order the entire set.. At that point might as well just replace the UICP.. UGH
Old May 25, 2010, 11:55 AM
kaj
kaj's Avatar
i had to position my coupling "just right" with a serious t-clamp. i tightened it down with my 3/8" drive cordless impact (unsure of tq). holds fine.
i've seen the OEM UICP on a dyno. it twists and swells at the rubber spots. very strange. not a bad idea to change it.
i need to get a metal piece as, for some reason (bad alignment), my rubber couplings either rub on the radiator fan shroud or the battery. i'm waiting to bust a hole in one.
Old May 25, 2010, 03:52 PM
nightwalker's Avatar
Everyone keeps forgetting that you need a clamp with thinner diameter band, whether it's a t-bolt or whatever. A 3" won't grab the coupler right, it will get caught on the wedge on the throttle body and not inbetween the two grooves to hold the hose in tight.
Old May 25, 2010, 04:45 PM
kaj
kaj's Avatar
Not everybody . That's what I meant by "just right". Not a single issue since.
Old May 25, 2010, 05:10 PM
mitsuclipsegsx's Avatar
What are some brands that you can use your stock battery besides injen?
Old May 25, 2010, 05:57 PM
thedru13's Avatar
Yah where can you get the JUST RIGHT size bands.. Can someone post exactly what to buy? I am game for anything.
Quick Reply: Upper Intercooler hose replacement
