Smallest size injector for e 85
Personally if you are going to pay to get injectors you should atleast get FIC 1450s. They are great for daily driving and give you plenty of room to grow. The last thing you want to do is get 1000cc injectors then a year down the road you get a larger turbo and need more. I made that mistake and I wish I went straight to 1450s... jmo
Mikey
Mikey
well my goal was 400whp, I got to my goal. Now im trying to figure out the best way to get closer to 500whp. My thoughts consist of E 85, bigger injectors, get an fp red or black etc etc
As far as fuel goes, you'll need injectors that can flow 1300cc or higher and a fuel pump and that can deliver enough fuel and pressure to keep up with them.
A single Walbro will flow a little over 4200cc of fuel at 3 bar. ...but if you're fuel pressure is increasing with boost it drops down to around 3600cc at 4 bar. To keep up with your injectors at full tilt (1300 x 4 = 5200cc) you will need a couple of pumps.
For an FP Black, you're going to need at least 1200cc and a double pumper to run E85. My buddy has that exact setup, made alittle over 500hp on the Krazy House Customs Mustang dyno, and ran 10.57 at the drag event he went to. That was the only run he got in before getting kicked!
