Intercooler couple question (quick and easy)
Is there a outlet size that the end of the coupler has to be to fit to the stock FMIC. My LICP is 2.5 and I just want to make sure the outlet size. Also what's a standard length size? I was going to purchase one online but I saw that the outlet and length sizes vary, there are also bends @ diff angles. What outlet size, length, and angle (if any) will I need for a proper fit to the stock FMIC. Just wanted to confirm here before I made a purchase. Thanks guys.
what intercooler are you looking at. i have had a turbo XS fmic that the inlet and outlet were around 2.75 and my pipes were 2.5. the ic came with reducing couplers. i have an ARC fmic and the inlet and outlet were like stock. i think about 2.25 so i was able to use the same couplers just used the small end to the IC and the big end still fit snub on the pipes. either way just going off memory but you can always find reducing couplers easily.
okay i just had a brain fart . just look at the stock coupler size. those will work with most IC pipes out there. and you can get stock replacement elbows if you want full sylicone ones.
TOKYO EVIL
21
Apr 27, 2017 06:59 PM
Jrod@Buschur
100
Oct 9, 2008 03:54 PM
antwon6420
Aug 15, 2007 12:00 PM
