Odd mild Vibration when turning
Hey all. I noticed I get a slight weird vibration when I make a slow right sometimes. . I tend to feel it in the pedals. I checked the tire pressures, all is good. Tires look fine as well. No real noises that I can tell either.
I recently had the timing belt done and had them check that cause I get a slight vibration in the pedals around 3500 rpm. But was told that the balance shaft and eveything is in line where it should be.
Any ideas off the top of your heads?
Im just wondering if it could be the tread pattern on the tire. I recently got the dunlop direzza z1's
If more info needed I can try to provide it.
thanks!
thanks!
Yeah its all stock fluids. I'd have to check to be sure. Had all my fluids done at AMS.
I read people talking about hub's transfer case, etc etc. But it doesnt do it every time. It so sporatic I check almost every time to see if I have a flat tire. lol
I'm heading up to AMS next week. Guess I'll have em look at that as well. /shrug
AMS's recipe usually consists of redline fluids. I'd definitely check to make sure what they put in. Either way I don't think it's much to worry about. Mine has done it since I bought the car a year ago, everything is still fine. I'm changing fluids to something different soon, I'll let you know what I find.
bluevilevo8
11
Sep 7, 2015 06:30 AM
fenriq007
13
Apr 16, 2009 08:44 PM
kouzman
Jun 29, 2007 07:19 AM
