mild whine sound 2003EVO8
driving the evo8 2003 I can hear a slight whining sound that fluctuate a bit its pretty mild really but when ur going low rpm 4th 5th gear u hear it most , the weird thing is I believe i also here it in neutral at times and sometimes it wont make the sound and sometimes it does I'v heard the major death whine can be transfer case but this isnt loud enough to hurt ears but it is loud enough to be annoying at times when its worst not sure and if it is transfer case how much could i expect to spend to have it rebuilt ? appreciate all the help here this is a great website ! was thinking possible wheel bearing or differential i want to say it sounds like its coming from the rear end but i can't tell for sure , recently had the car dyno tested and he never heard a problem but ofcourse it was so loud in there i dont think we would have known
http://www.sheptrans.com/transcase/evo.htm
does it sound like this?
http://www.youtube.com/watch?v=FdlocDJpfsI
thanks guys its way more mild then in that video so not sure but I'm going to have it checked out if it was the transfer case would it still do it in neutral ? cause mine does at times in neutral
These cars have a lot of whine. Gear whine from the trans is sometimes audible. I've had t-case death whine. It whines no matter what, on or off the throttle, and is loud. That being said, I recently replaced my broken OEM trans with another OEM unit, and each had its respective "whine" in different rpm's and speeds. If it is not as loud as the video shown I would not be too concerned.
Edit: It also gets louder as you increase load/speed. In other words, if you floor it in 3rd or 4th from around 3000 rpm till redline, does is get progressively louder? If not I doubt it is your t-case. People on here are so quick to say "its your t-case", but how many of you guys have experienced this first hand?
mine does the same thing, It has something to do with my powersteering pump i'm pretty sure, its a very faint whine, I can here it if I roll on the throttle, or when I rev it, when I cruise I can here it whine on low throttle from about 2.8k to 3.4k after that, it goes away. It also doesnt make the noise when i'm off the gas. I thought it was the TC too but now I have no clue, I just turn my music up so I cant hear it
pawpaw
10
Oct 9, 2016 03:17 AM
rcheung
95
Apr 21, 2008 11:06 AM
TeStUdO
14
Jun 30, 2006 08:11 AM
