dealer cleared CELs
dealer cleared CELs
i took my car in for the 5,000 mi service and i asked them to check the cel that came up (two i think). when i saw him at the counter he says, hum, cel, knock at 89 mph in blah blah gear @ blah blah rpm at that point i wasen't listening - having fun?
yep.
this black box tech is freaky. i guess i'd never get onstar tracking thing cause then the bushies (when they gain total power) will take control of all our cars!
paranoid in DC
yep.
paranoid in DC
actually most ECUs can calculate the gear, just by using the speed and engine RPM. that's how the SRT4 limits boost in 1st gear to add prevent absurd wheelspin.
I thought resetting the ecu by disconnecting the negative terminal of the battery erased any history of cel's that the ecu detected? In the manual, it says that if you get a CEL, you shouldn't disconnect the battery because they won't beable to diagnose it if you do.
This is partially true. If you disconnect the negative on the batttery it will clear a CEL, but not always the history. I know this first hand by going to have my emissions checked and I had a CEL. So naturally I disconnected the battery before I went. In IL they are now scanning your computer for past codes and also doing the sniffer test. At least that's what they did for me. They could tell that I had the battery disconnected recently and told me next time I would have to go to the dealer to have the codes cleared/fixed
