Recommended injectors for set up?
Set up as follows
ACT HD Street Clutch+Flywheel
Buschur TBE
K&N intake
HKS 272 Mivec Cams
MAPerformance o2 housing with dump pipe
walbro 255 fuel pump
Garret core FMIC custom built endtanks + LICP
Buschur TBE
K&N intake
HKS 272 Mivec Cams
1 Post
I went from stock injectors to FIC 850's while still on the stock turbo, then stepped up to the 1000's when I got a smokin' hot deal on them. I was not planning on upgrading anything again but that has all changed. LOL Large turbo necessitates larger injectors . . . again. If you are planning on making more upgrades later on I would just go with the 1000's now.
Josh
Josh
My set up is as follow. Fpred ported 80mm, ported exhaust mani and tb, ams fmic, kelford 272 cams, map o2 dump, head studs, supertech springs, tru boost controller, meth kit. So then 1000cc would be best for this set up? Maybe in the future I would do a stoker kit and bigger turbo but for now I'm sticking with this formula.
because you cant just run a huge injector on a setup that doesnt need it. its not like you can put 1600cc injectors on a stock car and everything will work right. the only injectors you can get away with that are the ID2200's, but they arent your everyday injectors and im sure you can see that by the price of them
