AFR not reading Correct..?
check the sensor.
take the sensor out and put some gas on a rag and put the sensor in it. turn key so the ignition and gauge is on, but car is not started. if it goes to full rich and stays there, the sensor is good. if it goes full rich then back to full lean or the 3 dashes, the sensor is bad
