Exhaust manifold bolt size
Old Jul 15, 2010 | 08:48 AM
vanisher's Avatar
Does anyone happen to know the size of the exhaust manifold bolt (exit side)?
I happened to lose on at the last track day (I know, wtf?). A part number would be nice as I would like to get a high grade bolt so it doesn't rust.
Thanks in advance.
Old Jul 15, 2010 | 09:23 AM
Bobster22388's Avatar
Thanks in advance.
The manifold is held on to the head by a stud and a nut, there aren't any bolts. There are also 2 different sizes for these. One being a 8x1.25mm and the other being a 10x1.25, I'm not sure on the length though. Just because a bolt is a higher grade doesn't mean it won't rust, just means it's stronger, you'd need a stainless bolt to make sure it doesn't rust.
Old Jul 15, 2010 | 09:24 AM
igo4bmx's Avatar
stainless corrodes at that temperature too
Old Jul 15, 2010 | 09:35 AM
SyZyGy1394's Avatar
Titanium would be pretty schweet for this application. Not as pointless as those titanium valve cover bolts that people buy.
Don't forget, when you couple a less noble metal to a more noble metal, it was cause the less noble metal to corrode faster.
True, forgot about the heat factor there.
Old Jul 15, 2010 | 09:38 AM
vanisher's Avatar
Sorry, I didn't mean the head side, I meant the turbo side.
would the same sizes apply?
Old Jul 15, 2010 | 09:51 AM
They are 10x1.25 for the manifold to turbo. I'm not sure on the length of those either.
Old Jul 15, 2010 | 10:05 AM
TouringBubble's Avatar
Man, really? I bought some 10x1.5mm since they seem to be the most common. Meh ... out $5 I guess. I went with 30mm length, but am not sure how correct that is as it was just a guess.
Old Jul 15, 2010 | 11:35 AM
Eh, you might be right on that one.
Old Jul 15, 2010 | 07:54 PM
vanisher's Avatar
FYI, I did some more serious searching and found this:
Bolt: MN119783 is the official part number and it's 10mm X 35mm
Stud: MN119784
Either way, yea hope it helps.
travaille
Aug 2, 2015 10:01 PM
Black_EVO_MR
Jan 15, 2015 02:46 PM
ebp99si
Jan 14, 2013 06:02 AM
meltdown
Jul 13, 2012 04:26 AM
udomaki
Dec 3, 2009 04:14 PM
Quick Reply: Exhaust manifold bolt size
