I have $50 for the person figures out my problem!
I already started a thread on my problem in the Ecuflash forum. But have not found a solution yet so I'm reaching out to hopefully find more help. I'm bleeding money like crazy replacing everything I can think of so it's worth $50 to me for an idea that works.
Here is the link:
https://www.evolutionm.net/forums/ec...g-f-ratio.html
Here is the link:
Check your EGR valve lines under the throttle body. They come off and give the symptoms you mention. Follow the lines off of the throttle body if you need a guide. There are 2 nipples that have vacuum lines. USUALLY the one you can't see, is the one that comes off.
did you ever extend your front o2 sensor due to installing a new o2 housing? my car had a bad misfiring issue and it was due to a couple of the wires getting crossed. after i fixed the wiring my car ran like new.
When I was doing a boost leak test a while back I did find a vacuum line back there that had came off. As you mentioned I couldn't see it but I felt around til I found a nipple near it and then reconnected it but it changed nothing. I suppose it's possible I could have attached it to the wrong place. Any idea where I could find a pluming diagram?
Checked out all the Vacuum lines and they are all connected correctly I was really hoping they weren't!
So on to the next idea someone in the other thread suggested replacing the ecu. But that's pretty expensive so I'd like a second opinion on that before I spend the $300
Dont you have any friends close to you who could help you by loaning you their ecu to try?
