balance shaft belt snapped, wont start,
well today driving when I shifted from first to second I felt something snap tehn lost all power and came to stop (I didnt here any knocking or clicking of valves, when it died it felt like the car had just cut fuel to the engine), before realizing what happened I lightly cranked it over and it wouldnt start, oil pressure light is on and I found teh balance shaft belt broken in the timing belt top cover.
I replaced both belts about 40 000km ago, it must have been to tight?
what am I looking at here for a repairs? is the engine ****ed? what should I check first.
any help would be much appreciated so I can get to work on this thing...
thanks,
Mathew
thanks,
Mathew
Crank angle sensor probably got damaged and lost signal. pull the left side apart and check the bottom timing belt area. You will have to pull the balancer off the crank (4 bolts) among other things.
Josh
Josh
possible internal engine damage? timing belt was stilll intact but ill replace both and double check the tightness when I do it this time oops
Your belt may have snapped from the balance shaft seizing in the bearing. This is why most built motors have balance shaft elimination. Removes a potentially weak problem from damaging a several thousand dollar built motor. Feel free to PM me or email me for more information.
Josh
Josh
The answer is no. However, if the balance belt went through the timing belt the timing belt may have jumped a tooth or few - another reason for not running balance shafts.
Balance shafts = Fail! The biggest issue with balance shafts is that they spin approximately 3 times as fast as your engine, which means that the shafts/bearing wear out faster than other engine components. As good as the shafts are the bad outweigh the good, I would definitely remove or eliminate them while you are doing this.
That is correct, Mitsubishi used balance shafts that are counter rotating and spinning at twice the speed of the engine in an attempt to MASK a 2nd order vibration that is inherent in inline 4 cylinder engines. The removal of the balance shafts will NOT harm your motor in anyway. The only side effect is more oil pressure and you may feel a very slight increase in vibration in the cabin of the car. Chances are you will never notice and since a lot of us already have solid mounts we could probably care less. Let me know if I can help with anything else.
Josh
Josh
Josh
