Stock Exhaust Fitment
Old Jul 22, 2010 | 01:34 PM
toyotabike's Avatar
Does anyone know if EVO 8 stock exhaust system is exactly the same as EVO 9?
Old Jul 22, 2010 | 01:42 PM
kwanza's Avatar
Which part of the exhaust?
I know that the 02 outlet and downpipe are the same for sure, I think the manifold, cat and cat back are also the same. The hotside of the turbo is not.
Old Jul 22, 2010 | 02:10 PM
toyotabike's Avatar
Starting from downpipe, cat, and cat-back. If I buy a stock cat from a evo 8, will it fit perfectly into my 9?
Old Jul 22, 2010 | 02:15 PM
eXtreme-Speed's Avatar
It might not because of the acd pump. If it was off of a 05 Evo 8 it may fit, but most likely not on a evo made before 05. But i may be wrong.
Old Jul 22, 2010 | 02:33 PM
BluEVOIX's Avatar
Downpipe: Depends if its ACD or not. Usually an ACD downpipe can fit a non ACD car, but not the other way around.
Cat: Evo 9 has o2 bung on the center section of the cat, Evo 8 does not.
Catback: Evo 8 catback has an o2 bung on the intermediate pipe, Evo 9 does not.
Other than those differences mentioned, everything else is a direct bolt on.
Old Jul 22, 2010 | 03:03 PM
sportsallstar's Avatar
i do not believe it will fit, you will most likely have to modify the downpipe
