Help no boost
Old Jul 22, 2010 | 07:25 PM
fenriq007's Avatar
Help no boost
So I had my cooling system flushed and thermostat replaced and now the car isn't boosting. It will rev all the way to redline if done slowly but once a tad bit of boost starts it just stalls out. Could something not been put back together correctly? What should i look for. Thanks for your help..
Old Jul 22, 2010 | 07:56 PM
MN_Evolution's Avatar
Check that your MAF is plugged in and do a boost leak test.
One of these two things IS your problem.
Old Jul 22, 2010 | 09:57 PM
jlaznlover's Avatar
a intercooler pipe might have came loose. check your pipes and try tightening your clamps.
Old Jul 22, 2010 | 10:53 PM
CJ2X's Avatar
^^ This sounds like your problem. Expecially if the car runs a little rocky when not boosting..
Old Jul 23, 2010 | 12:32 AM
white_evo27's Avatar
my LICP used to pop off the IC all the time, sounds like the same problem.... get tbolts
Old Jul 23, 2010 | 04:49 PM
cartuner08's Avatar
I'd say your IC pipes as well, I've had similar problems on my GST when it's silicone coupler tore.
Old Jul 23, 2010 | 05:28 PM
italianevo88's Avatar
yesterday my lower ICP blew off and I almost $**t my pants because it sounded like i blew my motor, and my car wouldnt rev past 1500
