Evo VIII
Evo VIII
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
Find a different car. One with no issues, if you can't afford that, chance are you can't afford one that needs work.
Good luck hunting.
white smoke is water if it dissapates pretty quick, blue smoke is usually burning oil, either way the evo isn't a cheap car to fix if you don't do your own maint... run like the wind bro
Does it smoke a lot less after a cold start up? If so it may be the valve seals...or 100 different problems.
If i had the chance to jump on a 10k evo with low miles (assuming the body is clean and the title is clear) I would do it without much hesitation. I wouldnt purchase it however with the concept of rushing it onto the road ASAP.
I wouldn't even think about it. It's easy to say if I get it for 6k cheaper than normal than I can buy a 2.4l block and yada but there's so much small things to that you'll need to do not to mention I bet if the engines junk, then there's a high chance of a faulty transfer case bad clutch turbo leaks tranny issues brake wear suspension issues, a ton of stuff u won't even see because a faulty engines staring you right in the face.
