Trans/Clutch Issue: 1st and Reverse...need ideas
Old Jul 29, 2010, 12:10 PM
chu
chu's Avatar
Originally Posted by turbotalawd
How old is your clutch fluid? When was the last time you changed it? Bleed it completely and put fresh new fluid in. Its possible that you could have cooked the fluid and its not doing its job properly.
I'm running ATE Super Blue. It's been in there for alittle over 1 year. I recently bled the clutch, and nothing. I dount I cooked the fluid autox'ing....I dont know anyone who has. THe brakes just dont generate enough heat for that.
Old Jul 29, 2010, 05:39 PM
turbotalawd's Avatar
I figured might as well start looking at the easy/cheap stuff first and see if thats the problem.
Old Jul 29, 2010, 05:44 PM
SyZyGy1394's Avatar
Put a better trans fluid in there.
Old Jul 29, 2010, 06:30 PM
chu
chu's Avatar
It can't be a fluid issue. I said, I can't get into first and reverse. All the other gear shift easily and smoothly. If the fluids were the problem, all the gears would feel notchy. You have a better recommendation than Amsoil MTG 75w90?
Old Jul 29, 2010, 07:01 PM
fastevo03's Avatar
It's not a fluid issue, I have changed the fluid and it's still same.
Old Jul 29, 2010, 07:07 PM
chu
chu's Avatar
May I ask how many miles is on your car? I've just been told a bend shift fork can also casue the issue, as it does not allow enough travel. I'm in the process of looking for that. I'm going to just replace it anyway while the trans is down. I have over 100k, so I can see it making sense! Maybe you should look into it also!
Old Jul 30, 2010, 09:19 AM
evozoom's Avatar
I have the same problem, just started around 110K miles. Only 1st and reverse. Trans not abused, oil synthetic - topped up and new. I'm wondering if its a worn linkage/cable problem (stretching due to age) as I assume the trans is actuated thru cables from the shifter....
Old Jul 31, 2010, 10:00 PM
fastevo03's Avatar
If it's linkage issue then you will have problem with all gears.
When the vehicle is rolling, i can get into 1st but once stationary then can't get into 1st. I will either put into 1st or reverse before start the engine
Old Aug 1, 2010, 02:36 AM
marcoEVO9's Avatar
check the under hood shifter bushings.
Old Aug 1, 2010, 06:31 AM
chu
chu's Avatar
ALready did. I have the Evo urethane bushings, and they're fine. Even greased it!
Old Aug 1, 2010, 10:32 AM
Berts24's Avatar
I had this issue when my clutch started to slip, this guy is also having your problem
https://www.evolutionm.net/forums/ev...oing-gear.html
Old Aug 1, 2010, 10:39 AM
chu
chu's Avatar
My clutch isn't clipping at all...we will find out tomorrow when the tranny comes down.
Old Aug 1, 2010, 05:01 PM
EVO8STI's Avatar
them twin disk exedy's at best only get about 20k on them before they go to ****, mine went about 15-16k, chattery little thing it was
Old Aug 1, 2010, 05:52 PM
2 ROWDY's Avatar
try changing your tranny fluid and adjusting the clutch pedal.
Old Aug 3, 2010, 04:02 PM
Berts24's Avatar
what's the verdict???
