speed density
a drawback of speed density is that it doesnt self compensate from what i understand. so if you change the set-up on your car, say put a bigger cam in, you will need to be tuned right away for the more air in the engine. now i understand that you should be tuned right away regardless if your on a MAF or SD, but on a MAF it will compensate as much as it can
plus since SD runs off of engine vaccum, adding a cam to SD for instance is really gonna mess up the previous SD tune in there. this is just one example.
i myself wouldnt call that a drawback because im one of those people that will get tuned right after my parts go on anyway
EvoJoeIX- I put those numbers down on VDR in about 90* heat and mild humidity but it was setup for dyno jet and uncorrected for the weather so I say its pretty close. I would agree your right on when talking about compensation with SD it doesn't "learn" as to say adding an intake on a MAF car, the car can make general small changes to make the car run better without a tune but on an SD car it will not know what you did and continue on its same fuel regiment. I think the driveability is ALOT better now and no jerky transition from closed loop to open loop fuel control when getting into boost.
If no changes are made to the tune OR if you are not running a Temp sensor to compensate for the intake charge temp. I do not have a IAT sensor and I have to change the tune around to get things in order between summer and winter cause the Air (in north carolina) gets really dense in the winter.
