I want gauges that are as close to oem lighting as possible but...
I am getting a 2.3 stroker built with an fp black. The Black really shines at higher boost levels. For 4 years now I have wanted the gruppe s 3 60 mm pod with defi gauges to make an oem like apperance. For one I forger which style gauge is the closest looking to the stock lighiting. What model is It? Well if I get tuned for 30 psi im fine since it only goes to 30 but what about at 35 psi. Then I will have a gauge that only goes to 30 . Im looking for the most stock looking setup lighitng wise. I was thinking getting defi egt, oil pressure, and oil temp. for the center pod. Along with the aem tru boost and also a aem wideband for atop the steering wheel colum. Any suggestions guys be much appreciated.
I don't think Defi offers a boost gauge that reads past 30psi (or 2bar), but Autometer does, and they now offer gauges in 60mm. They aren't as fancy as Defi gauges, but then again this isn't a car show either. I recommend Prosport because of the cost, but that all really depends on how deep your pockets are.
The reason I want oem looking gauge is because I want that. I do not want something that is blue or white, its to mismatched for me. Any one know of these autometer gauges, if they are close to stock looking. I seen on their site they have a cobalt line and a digital line. Are those the models you were telling me about?
You want the Defi-Link Meter ADVANCE BF. I have the older type of Defi BF gauges (Boost, EGT, Oil Pressure) in the Triple Gauge Panel with and AEM analog wide-band and analog flow meter in a 2-pod A-pillar. Looks great and matches stock lighting (Evo IX MR). The AEM gauges are slightly dimmer than the Defi, but the Defi can be adjusted.
You can set the Defi gauge to max warning of 30 PSI. When you boost over 30 you'll get an audiable and warning light. I have a 2.3L w/ FP Red and boost to 31-32 PSI. For me, I'd much rather have the Defi gauge that only goes to 30. I like the "warning" cause I know when I hit 30 PSI. Hopefully someday they'll come out with one that goes higher.
AEM stuff is good but it's no where near the same look as the OEM gauges. I suggest as someone else has to take a look at Prosport. Inexpensive and comes various colors that would match the stock gauges. Their wideband gauge can be used with wideband controllers like Zeitronix and Innovate if you want to have a real dependable wideband. Not so sure about how realiable the Prosport wideband controller would be. Maybe someone could tell of their experience with it. I want to add that the Prosport boost gauge reads past 30psi. I think 45-50psi?
thanks churchja and 4xforce. I dont mind spending the extra money for the defi its what I ve wanted for 4 years so I know if I dont get them then Ill be kicking myself later because of it. Isn't the aem inline wideband euego good enough for an afr gauge. Any one have an aem tru boost, thats replying in here?
I have a AEM 50psi boost guage and AEM wideband and both together light up red and are very uniform. You could always brighten your cluster up with brighter red led's .Defi's are for show , I had 6 of them in my sti way back. functional yes but if your tuned you dont need all them other guages, boost /air fuel work quiet well by itself. Also their mounted on the steering column, if you needed a 3rd guage where your looking you could use a aem oil psi or volts etc.. I dont mean to sound like im choosing one over the other because if defi was smart enough to produce a wideband and a higher reading boost guage im sure all the high hp cars would use them. Imo
Autometer has way more gauge lines that just the Cobalt and the Digital ones. I suggested them because they offer boost gauges that read past 30psi; Prosport and Defi do not offer this.
On the other hand, Prosport and Defi's gauges do look the most like stock, so it sounds like you're just gonna have to compromise on the max psi read out.
Autometer came out with a Nexxus line years ago that looks similar to Defi's and Prosports premium electric gauges, and they are expensive and require a $200 controller just to use them, just like Defi.
This thread makes me think of the vid that Prosport made of a customer that mainly wants the Defi gauges because he saw them in a magazine and they are a japanese product. If anyone else knows where this video is, please post it, haha!
The AEM's are good,I have the AEM Boost A/F and Oil Pressure its good to have Oil Pressure in case something happens you can know almost immediately. I have the Gruppe S Panel but in 52mm and I love it. I also have the brighter LED's and its almost as bright as the AEM gauges imo.
