Original Tial BOV spring in Tial Q?
Old Aug 1, 2010 | 11:10 AM
badev0's Avatar
Does anyone know if you can use a spring from the first/original Tial BOV in the new Tial Q?
Old Aug 1, 2010 | 11:18 AM
Smike's Avatar
Shoot Tial a call, they are local to you in MI.
Old Aug 1, 2010 | 11:30 AM
badev0's Avatar
I was planning on it tomorrow when they are open. Figured I'd make a post to find out sooner.
Old Aug 2, 2010 | 01:14 AM
FAST MN's Avatar
Yes. I think you have to switch it out if your on a stock ECU. Did you just put the BOV on and now having problems with idle?
Old Aug 2, 2010 | 07:43 AM
badev0's Avatar
Yeah the idle isn't the greatest anymore, because the spring is too soft and opening at idle. I found someone local with a stiffer spring, but its out of the original Tial.
Old Aug 2, 2010 | 05:44 PM
FAST MN's Avatar
I think I went though the same problem. I'm guess the spring in yours is a 0.6, I believe the new ones come in .6,.8,.10 and .12...the older ones came in .7, .9, .11. but they are color coded, I think .6 is green or blue and I had mine switched out to a white or .8 Then had a little tuned done, because had headstuds put in. started running fine as soon as we switched out the spring.
