Fuel pump time to replace
1 Post
I'd say make sure you set aside an hour from start to finish and buy the Walbro fuel pump with an install kit.
Also, follow this article:
http://www.evomoto.com/tech_articles...h_article_id=9
Take your time, and you'll be fine. It's a pretty easy upgrade.
-Bink
-Bink
I'm asking because I went to Mitsu to do a revision and asked How much would cost this service... The stupid guy told me that 6hours are necessary to change the pump... Ah, and told me that is needed to remove the gas tank!!!!
Dealers... take care!
its easy, you remove your back seat and there is an access panel. you should go back to the guy and tell him he's a ****en dumb *** or he is trying to make a ton of money off you. its an easy job for sure, just research it on here and do it yourself.
edit: i didn't see it was a 7 either, idk then
