E85 Question
#31
I'm confused, why would you do a build with a turbo that big, A) only to run 20-25 psi, and B) with H beam rods?
Why not utilize a more responsive turbo that is efficient in that boost range. A turbo that size should be 35psi minimum on e85...
#32
Whats wrong with h beams rods always used them never had a problem, as for the turbo i got it for a steal a deal i could not refuse, i am not going to run 35psi on a street car its not worth all that seriously 35psi on a street car is just way to much fuel consumption for me
#34
I would advise looking into the Buschur dual stage boos controller. With it, you can have two preset boost levels, one low and one high, and at the flip of a switch, cycle between the two. This way you can run your ~20psi 99% of the time and when you want to go a little more, flip the switch and run ~30psi. with that turbo, 30psi on 93 should be no problem at all....and safe.
#35
I run 37psi on my HTA Green it is one of the most fun street cars I have ever driven. As for the fuel, the consumption isn't that bad.
H-Beam rods weren't a great choice though. How much torque are you putting down now? Expect that to be increased by at least 50wtq or so, and if that number is over the 500ish mark, then I would be fearful of your rods. Eagles are also just a Chinese made rod that has been known to have serious issues with heavy torque motors...
#36
Edit: they also charge 350.00 for just that boost controller. For that much you could get everything I mentioned before and have it all setup nice for you...
#38
Have you considered driving up hwy 95 to AMS in Gaithersburg, MD? Drive up on a weekend, rent a car for a week, then pick up the following weekend.
With all the military with Evo's in the Norfolk area, I'd think you should probably investigate finding a shop with more Evo focus.
#40
you were running meth for 20 psi???
And you said 35 psi was too much for a street car??? A 40r is considered too much for a street car PERIOD, but since you have that 2.4 its liveable
everyone's right bro....that boost should come up.
#41
i feel you bro its to this point i dont know what to do i mean there giving me reasons why i need all this stuff and im also telling them what everyone up here is saying also which they seem to disagree with they also stated, that the paper fuel filter on the pump can not handle e85 so i needed to run a stainless steal filter has anyone heard of this
#42
That is totally b.s. ask anyone that runs ethanol on this forum if they are running different filters. I have had the same fuel filter on the walbro that has been in my tank for 3 years. I swapped to E-85, over a year ago and everything is still running like the day I switched.
I would really reconsider the shop you are going to...
#44
hey bro in response to your e85 question, here is a list of my buddys mods, his car made 377/377 with a conservative tune on e85, so i guess a question for you is, what HP goals are you looking to make?
E85
Walbro255
Precision 880cc Injectors
Aeromotive Fuel Rail
ARP STD Headstuds
TurboXS 3" turbo back exhaust with racepipe
EPM V1 O2dump
Injen Intercooler pipes with t-bolts
Forge RS BOV
Hallman Pro MBC
AEM UEGO & Boost gauges
E85
Walbro255
ARP STD Headstuds
EPM V1 O2dump
Forge RS BOV
Hallman Pro MBC
#45
Man I know I am going to get wasted for this question but trust me fellas before you burn me i did search for almost one hour and could not find a direct answer on what is needed for my setup. a basic run down of my car is
Motor:
Evo 9
2.4L 9:1 cr Fully Built
Super tech valve train
Cosworth 272/272 cams
Br Intake maifold (the factory upgrade)
Br 65mm tb
Pte 1000cc injectors
Br deluxe fmic
RSR 3inch tb exhaust
gt 4088 turbo
twin scroll manifold
aem engine mangement
walbro 255 intank
Factory fuel rail
I told the local shop that i wanted to switch to e85 now that i have it in my area the gave me a bill of over 2400 dollars . Now this was including fuel rail, intank double pumer, all the fancy fuel lines and fittings, fuel pressure regulator, labor and tuning is included in that price. I just wanted to know the rundown of the bare things needed to go e85 with that setup, and does it acutally cost this much, any help will be greatly helpful in this matter.
Motor:
Evo 9
Br 65mm tb
Br deluxe fmic
gt 4088 turbo
walbro 255 intank
Factory fuel rail
fancy fuel lines? why? Fuel rail? why? and with out larger injectors? It just seems like a waste. actually a lot about this seems like a waste. You can run high psi and be ok with fuel consumption. I run 28 psi, and when I keep it under boost, i manage 20+mpg city/ 25+ highway.
I'm going e85 soon, and the parts list for me is;
FIC1450cc $410
Wingz double pumper $350 (custom pump, only about $50 cheaper)
double pumper install $150
Speed Density conversion and tuning:
$250 single E85 SD map
$140 OMNI 4bar map sensor
$40 GM Intake Air Temp (IAT) with pigtail
install of these sensors $50
$85 for 3 pulls on the dyno
That should cover it.
