Vac line question
Vac line question
Say you have two identical boost controllers save one difference, one uses a larger vac input/output. Would it make it more effective at all? Does the size of the vac line make any difference at all (it has to to some extent, that I know)?
I have a blitz sbc-id, and it's vac nipple is about twice the size of the OE boost solenoid, so I have to use a reducer. Should I have a larger nipple welded to the turbo outlet, and somehow make the wg nipple larger to match? Will it make that much difference?
Thanks!
Thanks!
