noise on engaging..
noise on engaging..
im not really close to a dealer its why im asking... in few weeks ill go see a mitsu..
but i want to know if anyone has heard this noise at a moment...
its happening when i engage the clutch on 1st or reverse....i think its near the driveshaft... maybe a joint between shaft n rear diff, or tranny :O ??
the clutch is not in top shape but im not hard pushing all the time..
someone has an idea ?
what kind o noise?
I'm confused on OP's definition of engage. When you press the clutch in you are disengaging it, when the clutch is out it's engaged.
So does it happen clutch in at a stop going into first or reverse?? OR Does it happen while letting the clutch out in first or reverse as the clutch begins to engage??
it happen when in at a stop going into first..
Does it happen right when you shift it into 1st or right when you start moving from a stop?
I had a clunk sort of noise, it sounded like metal creaking on metal, but very very very low frequency so it sounded more like a couple clunks. It happened when starting from a stop or when coming to a stop. I saw some topics here about it, but none gave any very satisfactory info. I noticed it didn't seem to happen in the rain, so I figured it was something that water could lube up enough to prevent. I tightened up the bolts on the sway bars (I think that's what they're called?) 1/4-1/2 a turn and problem solved.
The transmission will make a clanging noise when it goes into gear. There is a silencer pad at where the steering column goes through the firewall. I threw mine out when I had the dash apart. Now, this noise is very apparent in the cabin.
ok nice to know, its same when rain no sound
