New Spark Plugs = Bad Idle????
Old Aug 16, 2010 | 08:19 PM
philevo's Avatar
I just installed NGK BPR7EIX 4055 on my 04 8 RS and after I started the car and it had a really rough idle. I turned the car off and checked to make sure everything was connected properly, it was. I turn the car back on and I got a cel, but my cool friend hooked up the scanner and deleted the code before we found out what it was. I drove home about 32 miles and the cel did not return but the idle is still rough. What happened?
Old Aug 16, 2010 | 08:27 PM
4RETECH's Avatar
Take them back out and check the gaps.
Old Aug 16, 2010 | 08:34 PM
FQ-300's Avatar
Any reason why you are not running the NGK BPR7ES (coppers)? Mods?
Old Aug 16, 2010 | 08:35 PM
philevo's Avatar
.026 all 4
Old Aug 16, 2010 | 08:38 PM
philevo's Avatar
Actually it was in stock and the car is stock.
Old Aug 16, 2010 | 08:40 PM
xmaciek82x's Avatar
Isn't .026 a bit too much on the stock coils? I thought you are suppose to be at .022.
Old Aug 16, 2010 | 08:44 PM
jhkim45's Avatar
Originally Posted by 4retech
take them back out and check the gaps.
+1
Old Aug 16, 2010 | 08:45 PM
RALLInspired's Avatar
what were they gapped to before? try .024 and if not .022.
FQ-300's Avatar
I run the same gap on my BPR7ES with no issues whatsoever.
Old Aug 16, 2010 | 08:47 PM
4RETECH's Avatar
Originally Posted by philevo
.026 all 4
This was after the rough running??
I would double check the plugs again, signs of cracking.
Good Luck
Old Aug 16, 2010 | 09:28 PM
Sinbig's Avatar
Stock specs
2003-04 .028-031
2005-06 .020-024
Most run .026 but max spec for 05-06's is .6 mm. .026" is .66 mm. Stick to specs unless you get to 26 psi of boost. Then tune your plugs with the rest
Old Aug 16, 2010 | 09:54 PM
TommiM's Avatar
for 2005 MY, specs are .024-.026". I dont know for sure if that also applies to 2003-04 though.
If your stock you shouldnt be having to gap smaller than .024". Even running them at .025" you should be fine. Something else is wrong, are you sure the coils and wires are in the correct cylinders?
Old Aug 16, 2010 | 10:22 PM
EVO8emUp's Avatar
You can't really mess the the firing order up since the coils bolt down and the wires run right to the other two plugs and the coils are the same.
Pull the in injector harnesses, one by one, until you find the cylinder that is misfiring. Unless your friends code reader can disable injectors.
Old Aug 17, 2010 | 10:22 PM
Derock2gspyder's Avatar
Good Luck
+1 bet you got a cracked plug or something along those lines! also maybe when you pulled the wires out they got messed up check inside the wires and make sure its all good!
Old Aug 17, 2010 | 10:48 PM
philevo's Avatar
Exclamation Update
I just put in BPR7ES gapped to .030, no more problems.
Thanks for all the help!
the code returned before I put in the the new plugs P0300.
Domengg Domino
Dec 3, 2016 08:00 AM
Domengg Domino
Dec 1, 2016 01:07 PM
Dylroche
May 31, 2016 11:51 PM
DanJ
Sep 6, 2013 04:01 PM
OPENA(671)
Sep 5, 2013 10:54 PM
Quick Reply: New Spark Plugs = Bad Idle????
