holding boost?
holding boost?
so i want to know what can i do to hold more boost towards redline rite now im boosting 27psi and tapering to 19-20psi. i have the stock dv not crushed stock wastegate so any info would help.
I used a vise and a nut to crush mine at first. Then to get the last bit needed I used a hammer. It'll hold 27 lbs now. It took some trial and error. You should be able to properly control your boost levels with that GM 3 Port. I am able to hold right around 26-27lbsl Its possible a little more time is needed with the tune to get it where you want it.
