throttle body plate sealant
installed it; throttle is smoother now and idle isnt bad. adjusted biss to try to hit 800-900 rpm and the car is fighting to hit 1000rpm so ill have to adjust ecuflash next for alightly higher timing and lower target idle. maybe over time throttle cable slightly stretched, retightening the cable made a big difference in throttle response. also because of the TB seals, i believe it eliminated a boost leak and now peak psi has increased by 1 psi.
i think the tb plate sealing is ok so far. though i found where i can get some molykte 321, so im gonna pick that up also later.
