Electrical Problems. Help Needed ASAP
Went to get my car (Evo8) tuned this weekend but it was a no-go. The OBD was unable to produce any power and therefore it is assumed that I have an electrical problem.
Here are more reasons for this justification:
1) Power Door locks switches dont work
2) A/C will not power on
3) Every other electrical part is in perfect working order.
This car has been in the shop for a engine swap, and my assumption is that a ground wire or some power cord has not been connected. If anyone has any idea, or advice for me in my problem please post or pm me. Email too (tootru9@Yahoo.com).
If anyone knows where the electrical grounds for the door locks and A/C power, please also let me konw.
I would start by checking your fuse boxes.
If its not a fuse it might be like you said, someone forgot to plug something back in. I would check wires after you check fuses.
Also you said there was an engine swap. Did the problem only show up after the swap?
