Dimmer Problem After Radio Install
So I finally decided to get a better radio for my Evo IX last night. After installing it the dimmer for my boost gauge and clock stopped working. I checked the wiring to the boost gauge and everything was fine. The odd thing is that my gauge cluster and my factory radio dimmer still works fine, I hooked up the factory radio again to see if that was the problem. I think this happened because I accidentaly wired the remote from the aftermarket radio to the dimmer on my car's harness because they were both blue wires. My question is does anyone know if I accidentally blew a fuse or any way I can fix this. Thanks.
My gauge cluster and radio lights dim when i turn on my headlights. The factory clock and my boost gauge dont dim anymore when I turn on the headlight. Would you know the location of the fuse so I can check it out?
Yea, the gauge cluster, clock, and radio lights will dim when you turn the lights on because they are wired into the headlight switch. I am not sure which fuse for you to check, it could be something internal in the headlight switch. Do your radio and boost gauge still light up and function?
Assassin
10
Apr 6, 2023 12:14 PM
silverevo05
Sep 1, 2010 10:12 AM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
