Just purchased 05 MR..brakes SQUEEEEKING please help
Old Aug 28, 2010 | 02:46 PM
THE8UH8's Avatar
I bought the car and drove it from atlanta (i live in NC) IT had hawk pads on it and would squeek right before i came to a stop. Well I changed all FOUR pads and its still doing it. It has slotted rotors. I think i may have to buy new ones...please help
Old Aug 28, 2010 | 02:50 PM
gsrboi80's Avatar
did you put anti squeel compound on the bac of the pads DO it = No more brake squeel
Old Aug 28, 2010 | 02:53 PM
THE8UH8's Avatar
Forgot to mention and yes i did
Old Aug 28, 2010 | 03:29 PM
silver97's Avatar
its probably just the material they are made of. Put it in reverse and drive it and pump the brakes could help with squealing
Old Aug 28, 2010 | 03:33 PM
monkey_187's Avatar
All brake pads will squeal a little every now and then. There is not a set that is completely noise free. After a while the noise should go away, on my X the noise was really bad. But eventually went away with more use.
Also, did you bed the brake pads in correctly?
Old Aug 28, 2010 | 03:39 PM
toyotabike's Avatar
Get used to it. Its an EVO.
Old Aug 28, 2010 | 03:48 PM
newevil's Avatar
In my experience hawks pads standard pads will squeak depending on the amount of heat in them , the type of pad lube & pad shims also the way that their broken in if their not broken in correctly (over heated) that can cause some squealing.
Old Aug 28, 2010 | 03:53 PM
whitegalant's Avatar
Oh man, my hawk hps pads are horrible. They have come to the point where they squeak horribly at every stop. I can deal with some but now its just starting to **** me off. Im only hard on the brakes every once in a while, not that often. Theres plenty of pad left so I dont want to get rid of them yet.
Old Aug 28, 2010 | 03:56 PM
evo8426's Avatar
ive been running hawk hps pads for 2 years and they dont squeal like they did when they were new
Old Aug 28, 2010 | 04:39 PM
gsrboi80's Avatar
On my 3rd set of pads and none ever squealed. Race compound pads will get noisy though.
I hate squeaky brakes
Old Aug 28, 2010 | 04:49 PM
MitsuJDM's Avatar
My pads squeal on occasion during very slow stops. Get used to it.
They're brand new Ferodo DS2500 or whatever.
Old Aug 28, 2010 | 05:42 PM
thedru13's Avatar
Mine sound like a train is coming to a stop. You think Hawk pads squeal you should hear my Forodos...
Old Aug 28, 2010 | 05:53 PM
THE8UH8's Avatar
how long is a while...
Old Aug 28, 2010 | 06:02 PM
Lightside's Avatar
I have hawk hps pads and when i first got them they squeaked terribly, worse then my factory brembo pads that were down to their squeak points. I asked my shop about it and their main mechanic said to just go out get up to about 80 and hit the brakes pretty hard a few times to heat them up. Worked like a charm for me!
Old Aug 28, 2010 | 06:08 PM
dac001's Avatar
