walbro fuel pump
walbro fuel pump
So I just bought a walbro fuel pump from a member, when it came in it was just the pump itself.
Is everything pretty much moved over from the stock pump to the aftermarket pump? such as the little white filter looking thing to the wires o rings ect?
I want to know before I start taking everything apart.
All the way at the bottom, mitsu filter/strainer $26 and a walbro install kit is all you should need.
Hope that helps.
looks that the kit should work for you.
http://www.lancershop.com/customer/p...cat=151&page=1
direct to the kit.
direct to the kit.
Fuel pump
Had one more question in regards to the walbro fuel pump..I bought a 255lph walbro off a member here supposedly it was new but when It came in it was obviously used before...
Is it safe to just switch the old filter over to the walbro fuel pump?
Also I believe there still is gas inside the walbro when i shake it i can hear liquid...is there anything to be cautious about or is that fine?
