Mishimito radiator install- Overheating
Did you install slimline with the radiator or kept the stock fans on there?
Stupid mistake I made before. I installed a new aftermarket radiator with a slimline fan. When I wired it up, I wired it up back word's so when it would kick on it was working against the wind so it caused it to over heat.
If not, another obviously thing(as everyone else has stated already) it would most likely be air in the cooling system.
best way is to put car on a ramp, then idle the car with heat on full blast. open the radiator cap and fill it up to the top and also the reservoir. soon engine will reach operating temp, hot water will start circulating through the block and heater core inside the cabin.
watch it and it will bubble and water level will drop within 5 minutes. top off alilttle more when you dont see any more bubble then cap the radiator... now wasnt that easy?
now besides mishimoto, could be coincidence your thermostat is dieing but doesnt sound like it from little info you gave us.
DViper0020
23
Jun 2, 2014 06:17 PM
DViper0020
23
May 15, 2014 10:18 AM
