Key sometimes hard to turn
Old Sep 9, 2010 | 02:08 PM
skaterdude888's Avatar
Hey, I don't know if anyone else has had a problem like this or what, but I bought an 03 evo8 about 2 months ago, and just yesterday and today I had difficulty turning the key in the ignition. It's almost as if its locked up, but after a few tries I can finally turn the key.
Is it possible my keys are just worn down or is it something else?
Old Sep 9, 2010 | 02:09 PM
Hi Im Vinh's Avatar
If the steering wheel is slightly cocked , try turning the wheel slightly left or right while turning the key . works for me
Old Sep 9, 2010 | 02:15 PM
devildevil's Avatar
i had trouble getting the key to the lock position the first week or so of owning mine... doesnt seem to do it anymore now.
Old Sep 9, 2010 | 03:18 PM
EVO8STI's Avatar
mine did this for a few months then stopped! but i also just turned the wheel and it always worked
Old Sep 9, 2010 | 03:35 PM
06MRV8Killer's Avatar
seriously.........?
Old Sep 9, 2010 | 04:34 PM
polish_pounder's Avatar
i sometimes have trouble getting it out haha
Old Sep 9, 2010 | 04:40 PM
evolution2186's Avatar
Spray a lubricant on the key. Insert in ignition. This will help as it did for mine.
Old Sep 9, 2010 | 04:45 PM
SLO-EVO's Avatar
dont do that. you run the risk of ruining the electronics in the ignition. if you are going to lube the key with anything, use graphite.
Old Sep 9, 2010 | 04:47 PM
Anonymouse's Avatar
Is this your first car? Try turning the wheel a little.
Old Sep 9, 2010 | 04:50 PM
i used a small amount and yes you always run this risk.
Old Sep 9, 2010 | 05:28 PM
Thanks for the quick replies. I'll try the steering wheel next time it happens, hopefully thats it.
Old Sep 9, 2010 | 05:40 PM
Steve Hischar's Avatar
It happens to me sometimes, just turn the wheel a bit and it will go no problem.
Old Sep 9, 2010 | 09:01 PM
Hi Im Vinh's Avatar
Just leave your steering wheel in the neutral position before turning it off and your fine next time you start it up.
