Making the evo more fun at the track
So I just took my Evo 8 to Summit Point last week for a track day for the first time on any track and it was a blast. Needless to say, I'm hooked. One concern I had was a mushy brake pedal on the last session, but I've read that this is most likely a brake fluid issue so I'm not too concerned. It's also starting to grind really bad going into 4th and 5th on a high rpm shift. I'm most likely going to take the car to CBRD to get everything checked out. I realize that I definitely need some better tires, brakes, suspension, etc but I'm unsure what to get. Since I am so new at this, my question is: what mods, specifically, would you recommend to make this car more fun at the track?
My current mods are listed below:
CBRD BBK Full Ported Turbo
CBRD Evo IX Turbo Adapter Kit
CBRD Race FMIC
CBRD LICP
Megan O2 Housing
PTE 780 Injectors
Perrin Intake
GSC S1 Cams
Invidia Downpipe
Cobb High-Flow Cat
DC Sports CBE
Hallman Pro FX MBC
Walbro 255lph Fuel Pump
Evo IX MR Diverter Valve
O2 Sensor Spacer
Shifter Bushings
Underhood Shifter Bushings
Clutchmasters Dual Plate Clutch
CBRD Race FMIC
CBRD LICP
Megan O2 Housing
PTE 780 Injectors
Perrin Intake
GSC S1 Cams
Invidia Downpipe
Cobb High-Flow Cat
DC Sports CBE
Hallman Pro FX MBC
O2 Sensor Spacer
Shifter Bushings
For the mushy pedal try SS braided brake lines and a better fluid like motul or amsoil, and upgrade your pads for something with a higher MOT. For the grinding between shifts the first suggestion is slow your shifts down. Also SS braided clutch lines, as those fluids and rubber hoses will suffer the same effects from heat as your brake lines. Perform proper maintainence by changing oil and all driveline fluids before (and after if your really ****) your session. I'm hoping to make it out to summit point soon, maybe I'll see you there.
I'm an instructor with NASA and Chin in the FL region. I hear this question all the time. Most people start thinking about more power, etc. Forget about all that. All you need is better fluid and better pads. I suggest Motul 600 for the fluid and some intermediate/advance pads. If you're really serious, I suggest that you skip intermediate pads and go to full race. Something like Performance Friction 01 or Hawk DTC-60's (they are expensive!). Intermediate compounds will be fine for a while, but will likely fail again as you move from novice to intermediate. As for tires, most experienced instructors recommend staying on street tires for a while. Street tires give you more feedback (mostly audible feedback) before they let go; they are just better for inexperience drivers. So I'd avoid R-compound tires until you become a good HPDE-3 driver, at least. Hope this helps.
Originally Posted by .MM
suspension!! TIRES!
your car seems to be all grunt and no handling
handling over power
handling over power
Stainless lines, high temp fluid, and some cooling ducts and youll be set up.
As for tires i would say just go on tirerack and get the stickiest cheep tires you can find youll wear them out fast and even faster as youre learning how to race
What's your problem? He asks for mods that make the car more fun, I recommend something that everyone who's gotten it says increases the fun factor of the car on the track. I'm not seeing your issue, and even if you disagree with me, no need to be a dick about it.
why wouldn't he be? upgraded rear diffs are starting to pick up lately and are one of the biggest factors in changing how the evo handles. not to mention the ones where you upgrade the stocker, like tre and shep, are fairly inexpensive.
some reviews here
https://www.evolutionm.net/forums/ev...ound-here.html
some reviews here
