Can someone help me asap! Im ordering in about an Hour need last opinions please..
So i need new set of rims and tires.
Im thinking about going with the Rota P45's 18x9+20
Can someone please tell me there recomendations on
HOW THEY WILL LOOK
If theres any fender work that will have to be done in front or rear
and if there is.. how much and about how much will I be looking at in cost...
My suspension is dropped on Swift Springs Spec-R
Thank you!!!
well im not a wheel guru, but since ur pressed on time ill throw out what i know. with ur car dropped n a +20 offset, if you run 255/35 or bigger you will most likely need fender work. n about how they will look...probably badass lol hope that helps. also there is the aggressive wheel thread that has TONS of info
Im a bit nervous about adding that offset on my car now. i keep reading it will reduce the way my car handles, and mess up a few things on my car, and that it takes alot of work to do it. ****t
^thats like saying "yeah dude, get that tattoo on ur forehead. it wont be that bad, plus it will look badass" haha if its gunna hurt performance and mess things up id just go with a less aggressive offset n look slightly less sick but still perform the way it should
https://www.evolutionm.net/forums/ev...el-thread.html
yes they will fit, rear fenders are going to have to be rolled and you will need 5mm spacers up front to clear the brembos, performance won't be affected, a little searching goes a long way
Okay well i ordered the 18x9.5+20 yesturday.
ima probobly go with 255/35/18 sized tire.
[QUOTE]
the reason I rushed it was because i have no choice bro, my side wall on my front tire is slightly torn and I have 2 screws in my back tire. <_<
Thats what i figured i would need also, but Dan from wheeldude told me i wouldnt need spacers for that size. Unless i misunderstood him, im doing all this ordering from work and its hard to keep fokissed.
[QUOTE]
Wow! Why would you rush into ordering something so quick without knowing all you need to know first? Hope you got all your questions answered within that hour.
RedLineSpeed
Sep 19, 2010 09:36 PM
youngun
Jan 30, 2008 07:54 PM
MetalSkull
Lancer Engine Tech
11
Aug 28, 2004 05:26 AM
